주요 콘텐츠로 건너뛰기
Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement
필요한 것
  1. Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement, Removing the Back Panel: 1 단계, 이미지 1/3 Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement, Removing the Back Panel: 1 단계, 이미지 2/3 Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement, Removing the Back Panel: 1 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement: 2 단계, 이미지 1/3 Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement: 2 단계, 이미지 2/3 Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement: 2 단계, 이미지 3/3
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
  3. Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement, Volume & Power Button Sensor: 3 단계, 이미지 1/2 Lenovo Tab 2 A8 Volume & Power Button Sensor Replacement, Volume & Power Button Sensor: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to gently lift the button panel away from the device. Be aware that pulling on the ribbon with too much force could tear the ribbon cable.
    • Carefully desolder the button strip contact point.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Taylor Smith
회원 가입일: 01/26/17
382 평판
안내서 2개 작성하였습니다
IUPUI, Team 2-4, Baechle Spring 2017 IUPUI, Team 2-4, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S2G4
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 38
전체 시간: 2,774
