주요 콘텐츠로 건너뛰기
Lenovo Tab 4 8 MicroSD Card Reader Replacement
필요한 것
  1. Lenovo Tab 4 8 MicroSD Card Reader Replacement, Battery: 1 단계, 이미지 1/3 Lenovo Tab 4 8 MicroSD Card Reader Replacement, Battery: 1 단계, 이미지 2/3 Lenovo Tab 4 8 MicroSD Card Reader Replacement, Battery: 1 단계, 이미지 3/3
    • Start at the microSD slot.
    • Use the opening pick to slide underneath the back cover of the tablet.
    • Slide the opening pick around the tablet until the back cover is off.
  2. Lenovo Tab 4 8 MicroSD Card Reader Replacement: 2 단계, 이미지 1/3 Lenovo Tab 4 8 MicroSD Card Reader Replacement: 2 단계, 이미지 2/3 Lenovo Tab 4 8 MicroSD Card Reader Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the 8 screws with a Phillips #000 screwdriver [bit].
    • There is a screw under the blue "s" sticker.
    • Remove tape holding plate down.
    • Use precision tweezers or your fingers to remove plate.
  3. Lenovo Tab 4 8 MicroSD Card Reader Replacement: 3 단계, 이미지 1/2 Lenovo Tab 4 8 MicroSD Card Reader Replacement: 3 단계, 이미지 2/2
    • Remove yellow tape.
    • Use a spudger or plastic opening tool to remove the battery's ribbon cable from the motherboard.
  4. Lenovo Tab 4 8 MicroSD Card Reader Replacement: 4 단계, 이미지 1/3 Lenovo Tab 4 8 MicroSD Card Reader Replacement: 4 단계, 이미지 2/3 Lenovo Tab 4 8 MicroSD Card Reader Replacement: 4 단계, 이미지 3/3
    • Gently pull on the two stretch release adhesive strips. Do not pull up, pull away from battery.
    • Once the tabs are off, lift the battery up from the frame.
    • Do not bend or puncture the battery.
  5. Lenovo Tab 4 8 MicroSD Card Reader Replacement, MicroSD Card Reader: 5 단계, 이미지 1/2 Lenovo Tab 4 8 MicroSD Card Reader Replacement, MicroSD Card Reader: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • There is a yellow tape holding the microSD card reader connector. Use tweezers to hold down the tape.
    • Gently lift the tab on the microSD card reader's ZIF connector, and gently pull the ribbon cable free.
  6. Lenovo Tab 4 8 MicroSD Card Reader Replacement: 6 단계, 이미지 1/2 Lenovo Tab 4 8 MicroSD Card Reader Replacement: 6 단계, 이미지 2/2
    • Lift the microSD card reader with tweezers or your fingers.
결론
Ivan Chavez
회원 가입일: 02/06/19
776 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 842
