주요 콘텐츠로 건너뛰기
Lenovo Tab 4 TB-8504F Battery Replacement
필요한 것
  1. Lenovo Tab 4 TB-8504F Battery Replacement, Battery: 1 단계, 이미지 1/3 Lenovo Tab 4 TB-8504F Battery Replacement, Battery: 1 단계, 이미지 2/3 Lenovo Tab 4 TB-8504F Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Start at the microSD slot.
    • Use the opening pick to slide underneath the back cover of the tablet.
    • Slide the opening pick around the tablet until the back cover is off.
  2. Lenovo Tab 4 TB-8504F Battery Replacement: 2 단계, 이미지 1/3 Lenovo Tab 4 TB-8504F Battery Replacement: 2 단계, 이미지 2/3 Lenovo Tab 4 TB-8504F Battery Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the 8 screws with a Phillips #000 screwdriver [bit].
    • There is a screw under the blue "s" sticker.
    • Remove tape holding plate down.
    • Use precision tweezers or your fingers to remove plate.
  3. Lenovo Tab 4 TB-8504F Battery Replacement: 3 단계, 이미지 1/2 Lenovo Tab 4 TB-8504F Battery Replacement: 3 단계, 이미지 2/2
    • Remove yellow tape.
    • Use a spudger or plastic opening tool to remove the battery's ribbon cable from the motherboard.
  4. Lenovo Tab 4 TB-8504F Battery Replacement: 4 단계, 이미지 1/3 Lenovo Tab 4 TB-8504F Battery Replacement: 4 단계, 이미지 2/3 Lenovo Tab 4 TB-8504F Battery Replacement: 4 단계, 이미지 3/3
    • Gently pull on the two stretch release adhesive strips. Do not pull up, pull away from battery.
    • Once the tabs are off, lift the battery up from the frame.
    • Do not bend or puncture the battery.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Ivan Chavez
회원 가입일: 02/06/19
776 평판
안내서 6개 작성하였습니다
댓글 한 개
Hi,
After replacing the battery, we now get an error “Temperature too high, will shut down” when we boot. We get the same error with the old battery installed. We tried a factory reset. That did not help. I’ve rechecked steps, and it is pretty straighforward. Any ideas?
Thanks,
Dave
David Burris - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 20
30일 전: 75
전체 시간: 6,360
