주요 콘텐츠로 건너뛰기
Lenovo Tab S8 Camera Replacement
필요한 것
  1. Lenovo Tab S8 Camera Replacement, Battery: 1 단계, 이미지 1/2 Lenovo Tab S8 Camera Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure the device is powered off.
    • Gently insert a spudger into one of the bottom corners between the screen and body case.
    • Slide the spudger along the inside of the crack in order to pry the case open.
    • Be careful of the small volume and power buttons when prying the case with the spudger. They are connected with small pieces of plastic that break easily.
  2. Lenovo Tab S8 Camera Replacement: 2 단계, 이미지 1/3 Lenovo Tab S8 Camera Replacement: 2 단계, 이미지 2/3 Lenovo Tab S8 Camera Replacement: 2 단계, 이미지 3/3
    • After removing the cover, remove the M1.6 x 2 mm screw from the battery cable with the JIS J000 screwdriver.
    • Using screwdriver bits that do not fit in the screw head might strip the screw and render it unusable.
    • Remove the tape by gently scraping the edges up with the spudger.
  3. Lenovo Tab S8 Camera Replacement: 3 단계, 이미지 1/3 Lenovo Tab S8 Camera Replacement: 3 단계, 이미지 2/3 Lenovo Tab S8 Camera Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Before removing the battery, be sure to disconnect the ribbon cables underneath it. The cables might stick to the battery during removal and cause damage.
    • Gently lift the flaps on the four ZIF connectors to disconnect the cables.
    • Use the plastic card to gently pry the battery from the device.
    • There may be glue holding the battery to the device. Use the spudger to detach any glue while the battery is partially raised by the card.
  4. Lenovo Tab S8 Camera Replacement, Camera: 4 단계, 이미지 1/3 Lenovo Tab S8 Camera Replacement, Camera: 4 단계, 이미지 2/3 Lenovo Tab S8 Camera Replacement, Camera: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use a plastic opening tool to gently pry the end of the camera's black ribbon cable (opposite the camera lens) off of the motherboard.
    • Once the cable is free, use tweezers to pull the camera from the body.
    • The camera may be stuck in place with a piece rubber foam. Take care to not damage the camera by applying too much pressure.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Thomas Rill
회원 가입일: 08/26/15
338 평판
안내서 2개 작성하였습니다
USF Tampa, Team 3-6, Eyestone Fall 2015 USF Tampa, Team 3-6, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S3G6
3 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 650
