주요 콘텐츠로 건너뛰기
Lenovo Tab S8 Motherboard Replacement
필요한 것
  1. Lenovo Tab S8 Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Lenovo Tab S8 Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure the device is powered off.
    • Gently insert a spudger into one of the bottom corners between the screen and body case.
    • Slide the spudger along the inside of the crack in order to pry the case open.
    • Be careful of the small volume and power buttons when prying the case with the spudger. They are connected with small pieces of plastic that break easily.
  2. Lenovo Tab S8 Motherboard Replacement: 2 단계, 이미지 1/3 Lenovo Tab S8 Motherboard Replacement: 2 단계, 이미지 2/3 Lenovo Tab S8 Motherboard Replacement: 2 단계, 이미지 3/3
    • After removing the cover, remove the M1.6 x 2 mm screw from the battery cable with the JIS J000 screwdriver.
    • Using screwdriver bits that do not fit in the screw head might strip the screw and render it unusable.
    • Remove the tape by gently scraping the edges up with the spudger.
  3. Lenovo Tab S8 Motherboard Replacement: 3 단계, 이미지 1/3 Lenovo Tab S8 Motherboard Replacement: 3 단계, 이미지 2/3 Lenovo Tab S8 Motherboard Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Before removing the battery, be sure to disconnect the ribbon cables underneath it. The cables might stick to the battery during removal and cause damage.
    • Gently lift the flaps on the four ZIF connectors to disconnect the cables.
    • Use the plastic card to gently pry the battery from the device.
    • There may be glue holding the battery to the device. Use the spudger to detach any glue while the battery is partially raised by the card.
  4. Lenovo Tab S8 Motherboard Replacement, Motherboard: 4 단계, 이미지 1/2 Lenovo Tab S8 Motherboard Replacement, Motherboard: 4 단계, 이미지 2/2
    • Use the tip of a spudger or your fingernail to flip up the small locking flap. Then, you can safely pull the cable out from under the camera.
  5. Lenovo Tab S8 Motherboard Replacement: 5 단계, 이미지 1/2 Lenovo Tab S8 Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the press-fit cable located next to the camera by using opening tool to gently pry it up.
    • Unlock the ZIF connector by lifting the black bar and sliding the ribbon cable out.
  6. Lenovo Tab S8 Motherboard Replacement: 6 단계, 이미지 1/3 Lenovo Tab S8 Motherboard Replacement: 6 단계, 이미지 2/3 Lenovo Tab S8 Motherboard Replacement: 6 단계, 이미지 3/3
    • Remove the five M1.6 x 2 mm screws from the motherboard with the JIS J000 screwdriver.
    • There is one screw hidden under a circular white sticker directly below the camera. Remove the sticker to take out the screw that is underneath it.
    • Cut or remove the piece of silver tape from the motherboard.
  7. Lenovo Tab S8 Motherboard Replacement: 7 단계, 이미지 1/3 Lenovo Tab S8 Motherboard Replacement: 7 단계, 이미지 2/3 Lenovo Tab S8 Motherboard Replacement: 7 단계, 이미지 3/3
    • Use the spudger to gently pry the motherboard out of the frame from each side.
결론
다른 6명이 해당 안내서를 완성하였습니다.
James Albu
회원 가입일: 08/26/15
608 평판
안내서 2개 작성하였습니다
USF Tampa, Team 3-6, Eyestone Fall 2015 USF Tampa, Team 3-6, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S3G6
3 회원들
안내서 11개 작성하였습니다
댓글 한 개
hi James,great guide there, I've removed a motherboard from a similar levono tablet and made.good a broken usb port, but now the thing is charging and booting fine, but the screen is unresponsive. No display or touch operation, any ideas? Tia
ga808ry - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 16
전체 시간: 4,767
