주요 콘텐츠로 건너뛰기
Lenovo Tab S8 Power Button Replacement
필요한 것
  1. Lenovo Tab S8 Power Button Replacement, Power Button: 1 단계, 이미지 1/3 Lenovo Tab S8 Power Button Replacement, Power Button: 1 단계, 이미지 2/3 Lenovo Tab S8 Power Button Replacement, Power Button: 1 단계, 이미지 3/3
    • Make sure the device is powered off
    • Gently insert a spudger into one of the bottom corners between the screen and body case. Gently slide the spudger along the inside of the crack to pry the case open
    • Be careful of the small volume and power buttons when prying the case with the spudger. They are connected with small pieces of plastic that break easily.
  2. Lenovo Tab S8 Power Button Replacement: 2 단계, 이미지 1/3 Lenovo Tab S8 Power Button Replacement: 2 단계, 이미지 2/3 Lenovo Tab S8 Power Button Replacement: 2 단계, 이미지 3/3
    • Gently lift the clear-yellow rubber flap from the plastic pegs with a plastic opening tool.
    • The rubber flap secures the button to the casing, and it falls out easily.
결론
James Albu
회원 가입일: 08/26/15
608 평판
안내서 2개 작성하였습니다
USF Tampa, Team 3-6, Eyestone Fall 2015 USF Tampa, Team 3-6, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S3G6
3 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 11
전체 시간: 1,956
