주요 콘텐츠로 건너뛰기
Lenovo ThinkPad E15 Gen 3 Speakers Replacement
필요한 것
  1. Lenovo ThinkPad E15 Gen 3 Speakers Replacement, Battery: 1 단계, 이미지 2개 중 1개 Lenovo ThinkPad E15 Gen 3 Speakers Replacement, Battery: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Phillips #1 Screwdriver
    $5.49
    • Loosen the eight PH1 screws on the back panel using the Phillips #1 screwdriver.
    • These screws stay seated within the back panel so do not try to remove them.
  2. Lenovo ThinkPad E15 Gen 3 Speakers Replacement: 2 단계, 이미지 3개 중 1개 Lenovo ThinkPad E15 Gen 3 Speakers Replacement: 2 단계, 이미지 3개 중 2개 Lenovo ThinkPad E15 Gen 3 Speakers Replacement: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    iFixit Opening Tool
    $1.99
    • Remove back panel using a plastic opening tool or a spudger.
    • Ensure that all sides of the panel are separated (audible clicks will be heard when separating) from the device frame.
  3. Lenovo ThinkPad E15 Gen 3 Speakers Replacement: 3 단계, 이미지 2개 중 1개 Lenovo ThinkPad E15 Gen 3 Speakers Replacement: 3 단계, 이미지 2개 중 2개
    • Gently disconnect the battery from the motherboard by pulling on the fabric tab attached to the connector.
  4. Lenovo ThinkPad E15 Gen 3 Speakers Replacement: 4 단계, 이미지 2개 중 1개 Lenovo ThinkPad E15 Gen 3 Speakers Replacement: 4 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws holding the battery.
  5. Lenovo ThinkPad E15 Gen 3 Speakers Replacement: 5 단계, 이미지 3개 중 1개 Lenovo ThinkPad E15 Gen 3 Speakers Replacement: 5 단계, 이미지 3개 중 2개 Lenovo ThinkPad E15 Gen 3 Speakers Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the battery by gently lifting the top of the battery out from the frame and then pull towards the motherboard.
  6. Lenovo ThinkPad E15 Gen 3 Speakers Replacement, Speakers: 6 단계, 이미지 2개 중 1개 Lenovo ThinkPad E15 Gen 3 Speakers Replacement, Speakers: 6 단계, 이미지 2개 중 2개
    • Use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
    • Don't push on the cables themselves, or you may damage the connector.
  7. Lenovo ThinkPad E15 Gen 3 Speakers Replacement: 7 단계, 이미지 2개 중 1개 Lenovo ThinkPad E15 Gen 3 Speakers Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the speakers from the device.
    • The cables connecting the speakers may need to be gently untucked from the small plastic hooks bordering the battery.
    • Take note of how the speakers and their wires are arrayed, as you will need to arrange them in the same positions.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Benjamin Harrell
회원 가입일: 04/14/25
259 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 13
전체 시간: 162
