주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Edge E420s Battery Replacement
필요한 것
  1. Lenovo ThinkPad Edge E420s Battery Replacement, Hard Drive: 1 단계, 이미지 1/1
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Lenovo ThinkPad Edge E420s Battery Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove one M2 x 3mm screw from the side of the device.
  3. Lenovo ThinkPad Edge E420s Battery Replacement: 3 단계, 이미지 1/3 Lenovo ThinkPad Edge E420s Battery Replacement: 3 단계, 이미지 2/3 Lenovo ThinkPad Edge E420s Battery Replacement: 3 단계, 이미지 3/3
    • Swing the cover out slightly like a hinge.
    • Pull the cover directly away from the case towards the base of the laptop.
    • Lift the cover up and away from the device to remove it.
    • You may hear a slight pop when you pull the cover off.
  4. Lenovo ThinkPad Edge E420s Battery Replacement: 4 단계, 이미지 1/1
    • Use the clear tab to slide the hard drive out of the device.
  5. Lenovo ThinkPad Edge E420s Battery Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad Edge E420s Battery Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad Edge E420s Battery Replacement: 5 단계, 이미지 3/3
    • To replace the hard drive, remove the four M2 × 4mm wafer-headed screws on the sides of the hard drive case using a Phillips #00 screwdriver.
    • Slide the old hard drive directly out.
    • When reassembling, make sure the hard drive is securely in the case before beginning.
  6. Lenovo ThinkPad Edge E420s Battery Replacement, Top Case: 6 단계, 이미지 1/2 Lenovo ThinkPad Edge E420s Battery Replacement, Top Case: 6 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove eight M2 × 3 mm screws near the front opening and scattered across the bottom of the laptop.
    • Remove three M2x3 mm screws using a Phillips #00 screwdriver from the base of the laptop near the opening.
  7. Lenovo ThinkPad Edge E420s Battery Replacement: 7 단계, 이미지 1/1
    • Remove the M3 x 2mm screw from the hole left by the hard drive using a Phillips #00 screwdriver.
  8. Lenovo ThinkPad Edge E420s Battery Replacement: 8 단계, 이미지 1/2 Lenovo ThinkPad Edge E420s Battery Replacement: 8 단계, 이미지 2/2
    • Flip over the device.
    • Open the device normally.
  9. Lenovo ThinkPad Edge E420s Battery Replacement: 9 단계, 이미지 1/1
    • Wedge the plastic opening tool between the upper and lower halves of the lower case.
    • Lift the end of the opening tool slowly until the case separates.
    • Hearing a small popping or cracking noise during this step is normal
  10. Lenovo ThinkPad Edge E420s Battery Replacement: 10 단계, 이미지 1/1
    • Lift the upper half of the case up slowly.
    • Be sure not to yank any of the wires connected to the case as this could damage them.
  11. Lenovo ThinkPad Edge E420s Battery Replacement: 11 단계, 이미지 1/3 Lenovo ThinkPad Edge E420s Battery Replacement: 11 단계, 이미지 2/3 Lenovo ThinkPad Edge E420s Battery Replacement: 11 단계, 이미지 3/3
    • Locate and disconnect the 4 ribbon wires from the top case.
    • Locate and disconnect the two additional connecting wires.
    • Some wires may be connected by a clamp. In order to remove the clamp, press upwards on the lever attached to the connector
    • Be careful to not yank on the wires when disconnecting them as they are easily damaged.
  12. Lenovo ThinkPad Edge E420s Battery Replacement: 12 단계, 이미지 1/1
    • Lift the unattached case away from the device and place it to the side.
    • When reassembling ensure that all parts of the case are properly aligned.
  13. Lenovo ThinkPad Edge E420s Battery Replacement, Battery: 13 단계, 이미지 1/2 Lenovo ThinkPad Edge E420s Battery Replacement, Battery: 13 단계, 이미지 2/2
    • Disconnect the cable connecting the battery and the motherboard
  14. Lenovo ThinkPad Edge E420s Battery Replacement: 14 단계, 이미지 1/2 Lenovo ThinkPad Edge E420s Battery Replacement: 14 단계, 이미지 2/2
    • Lift the battery out of the case.
    • The battery is secured by grey plastic tubes passing through the case. To place the battery back in, line up the openings on the battery with the tubes.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Keyadri Summerlin
회원 가입일: 10/02/18
1,003 평판
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 13
전체 시간: 1,299
