주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Edge E470 Hard Drive Replacement
필요한 것
  1. Lenovo ThinkPad Edge E470 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Disconnect the power cord from your computer.
  2. Lenovo ThinkPad Edge E470 Hard Drive Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad Edge E470 Hard Drive Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad Edge E470 Hard Drive Replacement: 2 단계, 이미지 3/3
    • Restart the computer and press F1 button rapidly to enter BIOS.
    • Select “Config,” then select “Power,” and press Enter.
    • Select “Disable Build-in Battery” and press "Enter."
  3. Lenovo ThinkPad Edge E470 Hard Drive Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad Edge E470 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Place the laptop upside down to access the back panel.
    • Loosen the three screws on the back panel using a Phillips #00 screwdriver.
    • Remove the back panel.
  4. Lenovo ThinkPad Edge E470 Hard Drive Replacement: 4 단계, 이미지 1/2 Lenovo ThinkPad Edge E470 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Disconnect the battery plug.
  5. Lenovo ThinkPad Edge E470 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Disconnect the SATA cable for the storage drive from the computer.
  6. Lenovo ThinkPad Edge E470 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Loosen the screw on the storage drive using a Phillips #00 screwdriver.
  7. Lenovo ThinkPad Edge E470 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Remove the storage drive.
  8. Lenovo ThinkPad Edge E470 Hard Drive Replacement: 8 단계, 이미지 1/2 Lenovo ThinkPad Edge E470 Hard Drive Replacement: 8 단계, 이미지 2/2
    • Take the storage drive out of the storage drive bracket.
  9. Lenovo ThinkPad Edge E470 Hard Drive Replacement: 9 단계, 이미지 1/1
    • Disconnect the SATA cable from the storage drive.
  10. Lenovo ThinkPad Edge E470 Hard Drive Replacement: 10 단계, 이미지 1/2 Lenovo ThinkPad Edge E470 Hard Drive Replacement: 10 단계, 이미지 2/2
    • Connect the SATA cable to the computer. Remember to push the lip down.
결론
To reassemble your device, follow these instructions in reverse order. Remember to push back the lid on the SATA connector.
다른 2명이 해당 안내서를 완성하였습니다.
Jinxiao Zhou
회원 가입일: 05/29/23
208 평판
안내서 1개 작성함
York University, Team A-10, Allen Summer 2023 York University, Team A-10, Allen Summer 2023 회원
YORK-ALLEN-SU23SAG10
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 41
전체 시간: 298
