소개
This guide will help to replace the front compartment case of the Lenovo Thinkpad Edge E520.
필요한 것
Flip over the laptop and position it with the battery being furthest away from you.
Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
Unscrew the two 3.175 mm diameter and 6.35 mm length screws with keyboard symbols pointing at them using a Phillips head screwdriver.
Remove all remaining screws on the back of the device.
Screw length 6.35 mm, head 3.175 mm Screws behind battery length 3.175 mm, head 3.175 mm
다른 한 분이 해당 안내서를 완성하였습니다.
