주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Edge E520 Hard Drive Replacement
필요한 것
  1. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Power off and unplug the computer before the start of these steps.
    • Close the laptop lid.
  2. Lenovo ThinkPad Edge E520 Hard Drive Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad Edge E520 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Flip the computer so that the back is facing upwards.
    • Locate the switch used to release the battery.
    • The switch should be located towards the hinge of the laptop near the battery pack and have a lock icon associated with it.
  3. Lenovo ThinkPad Edge E520 Hard Drive Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad Edge E520 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Slide the switch towards the unlocked lock icon.
    • While holding it in the unlocked position, slide the battery towards the hinge.
    • Fully separate the battery pack from the back of the laptop.
  4. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Back Plate: 4 단계, 이미지 1/2 Lenovo ThinkPad Edge E520 Hard Drive Replacement, Back Plate: 4 단계, 이미지 2/2
    • Flip over the laptop and position it with the battery being furthest away from you.
    • Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
    • Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
    • Screw length 6.35 mm, head 3.175 mm
  5. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/3 Lenovo ThinkPad Edge E520 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2/3 Lenovo ThinkPad Edge E520 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 3/3
    • Position the laptop so that the battery compartment is facing away from you.
    • Remove the two bracket screws on the bottom of the hard drive.
    • Gently lift out the hard drive with its bracket still attached.
    • Remove the bracket from the hard drive.
결론
다른 3명이 해당 안내서를 완성하였습니다.
David Skarbek
회원 가입일: 03/01/18
271 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S1-G2, Simcock Spring 2018 UMass Dartmouth, Team S1-G2, Simcock Spring 2018 회원
UMASSD-SIMCOCK-S18S1G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 16
전체 시간: 1,418
