소개
This guide will tell you how to replace the RAM in your Lenovo Thinkpad Edge E520.
필요한 것
Flip over the laptop and position it with the battery being furthest away from you.
Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
다른 2명이 해당 안내서를 완성하였습니다.
