주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Edge E520 RAM Replacement
필요한 것
  1. Lenovo ThinkPad Edge E520 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Power off and unplug the computer before the start of these steps.
    • Close the laptop lid.
  2. Lenovo ThinkPad Edge E520 RAM Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad Edge E520 RAM Replacement: 2 단계, 이미지 2/2
    • Flip the computer so that the back is facing upwards.
    • Locate the switch used to release the battery.
    • The switch should be located towards the hinge of the laptop near the battery pack and have a lock icon associated with it.
  3. Lenovo ThinkPad Edge E520 RAM Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad Edge E520 RAM Replacement: 3 단계, 이미지 2/2
    • Slide the switch towards the unlocked lock icon.
    • While holding it in the unlocked position, slide the battery towards the hinge.
    • Fully separate the battery pack from the back of the laptop.
  4. Lenovo ThinkPad Edge E520 RAM Replacement, Back Plate: 4 단계, 이미지 1/2 Lenovo ThinkPad Edge E520 RAM Replacement, Back Plate: 4 단계, 이미지 2/2
    • Flip over the laptop and position it with the battery being furthest away from you.
    • Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
    • Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
    • Screw length 6.35 mm, head 3.175 mm
  5. Lenovo ThinkPad Edge E520 RAM Replacement, RAM: 5 단계, 이미지 1/1
    • The blue tinted rectangular chips will be located opposite of the hinge.
    • They are stacked on top of one another and the second chip will be found underneath the top one.
  6. Lenovo ThinkPad Edge E520 RAM Replacement: 6 단계, 이미지 1/2 Lenovo ThinkPad Edge E520 RAM Replacement: 6 단계, 이미지 2/2
    • Locate the two thin metal tracks that hold each RAM in place.
    • Using light pressure, press the tracks outward and the RAM should pop up.
  7. Lenovo ThinkPad Edge E520 RAM Replacement: 7 단계, 이미지 1/1
    • A light pull on the RAM should remove it with no issues.
    • Repeat from the second step to the third step to remove the second chip.
    • On reassembly, the RAM may provide some difficulty to put it back in. Be patient and slide the ram back in the metal track and apply pressure to make sure that it is in.
    • Be sure that it is in the track so the pins do not bend. A "click" sound may be heard to indicate when it is fully seated.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Andrew Martin
회원 가입일: 03/01/18
217 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G2, Simcock Spring 2018 UMass Dartmouth, Team S1-G2, Simcock Spring 2018 회원
UMASSD-SIMCOCK-S18S1G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 16
전체 시간: 1,037
