주요 콘텐츠로 건너뛰기
Lenovo ThinkPad HK11e Battery Replacement
필요한 것
  1. Lenovo ThinkPad HK11e Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the Lenovo laptop is shut off.
    • Turn over laptop and lay it on its face exposing the back-plate screws.
  2. Lenovo ThinkPad HK11e Battery Replacement: 2 단계, 이미지 1/1
    • Find the six screws that hold together the back plate.
    • Carefully unscrew the six 3.3 mm screws that fasten the back plate using the T5 Torx screwdriver.
  3. Lenovo ThinkPad HK11e Battery Replacement: 3 단계, 이미지 1/1
    • Use a plastic opening tool or a spudger to carefully remove the back plate.
  4. Lenovo ThinkPad HK11e Battery Replacement: 4 단계, 이미지 1/1
    • Battery is located in the bottom right portion of the laptop.
    • Find the three screws that mount the battery.
    • Carefully unscrew the three 3.5 mm screws that fasten the battery down using the T5 Torx screwdriver.
  5. Lenovo ThinkPad HK11e Battery Replacement: 5 단계, 이미지 1/1
    • Notice a connector that joins the battery to the laptop.
    • Slowly disconnect the connector by pulling back on the six-wire harness.
  6. Lenovo ThinkPad HK11e Battery Replacement: 6 단계, 이미지 1/1
    • Remove the battery from its assigned location.
  7. Lenovo ThinkPad HK11e Battery Replacement: 7 단계, 이미지 1/1
    • Reverse steps to mount new battery correctly.
결론
Sam Dahdal
회원 가입일: 01/31/19
145 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 35
전체 시간: 257
