주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad Helix Battery Replacement
필요한 것
  1. Lenovo ThinkPad Helix Battery Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Using a plastic opening tool or opening pick, gently pry the screen off.
    • If possible, use plastic tools to pry the screen, as the metal tool as shown in the image can potentially damage your device.
    • You will need to use a little bit of force to pry it open. There is little indent that goes around the tablet. You will insert your tool between this indent and pry it open.
    • Once you're able to lift a little bit of the screen away from the tablet, work your way around until screen is separated from tablet. Stop for step two.
  2. Lenovo ThinkPad Helix Battery Replacement: 2 단계, 이미지 3개 중 1개 Lenovo ThinkPad Helix Battery Replacement: 2 단계, 이미지 3개 중 2개 Lenovo ThinkPad Helix Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Lift the screen up slowly.
    • Once separated, you can not fully take it off due to some cable connections.
    • Open the clips of the ZIF connectors and gently grab the cable to pull it out.
  3. Lenovo ThinkPad Helix Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Once the cables are disconnected, remove the screen.
  4. Lenovo ThinkPad Helix Battery Replacement, Battery: 4 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, unscrew the four nylon-coated 3 mm screws holding the battery in place.
  5. Lenovo ThinkPad Helix Battery Replacement: 5 단계, 이미지 2개 중 1개 Lenovo ThinkPad Helix Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Disconnect the battery cable from the motherboard.
    • Lift the battery out of the device.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Manuel Parra Rocha
회원 가입일: 08/26/19
494 평판
안내서 2개를 작성함
Gateway, Team S1-G6, Saknee Fall 2019 Gateway, Team S1-G6, Saknee Fall 2019 회원
GCC-SAKNEE-F19S1G6
4 회원들
안내서 3개를 작성함
1가이드 댓글
Hi, would you possibly have an explanation as to why a replacement battery is still not charging and yielding error messages? Thank you.
M.H. L. - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 76
전체 시간: 8,418
