주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad L460 LCD Assembly Replacement
필요한 것
  1. Lenovo ThinkPad L460 LCD Assembly Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Shut down your Lenovo ThinkPad L460 completely.
    • Disconnect the AC power adapter.
    • Disconnect all connected cables and devices.
  2. Lenovo ThinkPad L460 LCD Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Flip the laptop so the bottom is facing upwards.
  3. Lenovo ThinkPad L460 LCD Assembly Replacement: 3 단계, 이미지 2개 중 1개 Lenovo ThinkPad L460 LCD Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Use your two thumbs to push the two locking latches to the left and the right of the battery to the unlocked position.
    • While holding the latches open, slide the battery out of the connector to remove it.
  4. Lenovo ThinkPad L460 LCD Assembly Replacement, Back Cover: 4 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to loosen the 8 captive screws on the back cover of the laptop.
    • Captive screws are not meant to be removed, just loosened enough.
    • Remove the SIM tray from the side of the laptop.
  5. Lenovo ThinkPad L460 LCD Assembly Replacement: 5 단계, 이미지 2개 중 1개 Lenovo ThinkPad L460 LCD Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • Use an opening tool to gently pry along the edges of the cover, releasing all the plastic clips of the laptop.
    • Carefully pull up and remove the back cover from the laptop.
  6. Lenovo ThinkPad L460 LCD Assembly Replacement, LCD Assembly: 6 단계, 이미지 2개 중 1개 Lenovo ThinkPad L460 LCD Assembly Replacement, LCD Assembly: 6 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove the four 6 mm screws and a Phillips #0 screwdriver to remove the two 5 mm screws from the hinges at the corners of the laptop.
  7. Lenovo ThinkPad L460 LCD Assembly Replacement: 7 단계, 이미지 3개 중 1개 Lenovo ThinkPad L460 LCD Assembly Replacement: 7 단계, 이미지 3개 중 2개 Lenovo ThinkPad L460 LCD Assembly Replacement: 7 단계, 이미지 3개 중 3개
    • Flip the black plastic cover up to reveal the Wi-Fi card.
    • Slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the coaxial cable connectors (as close to the head as possible) and lift straight up from the Wi-Fi card.
    • To make the display connector easier to access, disconnect the two white JST connectors next to it before disconnecting the display connector.
    • Use a spudger or a clean fingernail to flip up the locking flap on the display connector—this is the unlocked position.
    • Use tweezers or your fingers to gently pull the cable out of its socket.
  8. Lenovo ThinkPad L460 LCD Assembly Replacement: 8 단계, 이미지 1개 중 1개
    • Carefully remove the cables from the cable guides.
  9. Lenovo ThinkPad L460 LCD Assembly Replacement: 9 단계, 이미지 2개 중 1개 Lenovo ThinkPad L460 LCD Assembly Replacement: 9 단계, 이미지 2개 중 2개
    • Flip up the two hinged plates on the sides of the laptop.
    • Remove the LCD assembly from the laptop.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
작성자
3다른 기여자 명과 함께
Jacob Karl
회원 가입일: 10/17/25
109 평판
안내서 1개를 작성함
UMass Dartmouth, Team 2-4, Bowman Fall 2025 UMass Dartmouth, Team 2-4, Bowman Fall 2025 회원
UMASSD-BOWMAN-F25S2G4
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 45
전체 시간: 194
