주요 콘텐츠로 건너뛰기
Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement
필요한 것
  1. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Remove base cover: 1 단계, 이미지 1/1
    • Remove the 7 screws holding the base cover in place.
    • Remove the base cover.
  2. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Unplug the battery: 2 단계, 이미지 1/1
    • Peel up the insulated sheet from the battery connector.
    • Unplug the battery connector in the direction showed by the arrow.
  3. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Remove the battery screws: 3 단계, 이미지 1/1
    • Remove the two M2 × L4 mm, flat-head screws.
    • Remove the two M2 × L5 mm, flat-head, screws.
  4. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Remove the battery: 4 단계, 이미지 1/1
    • Remove the battery.
결론
To replace the battery & reassemble your device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Max Kletskov
회원 가입일: 04/22/20
40,307 평판
안내서 16개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,271개 작성하였습니다
댓글 3개
Great Thank you for info
Brad - 답글
Will this battery generate a Bios not authentic battery warning? Other replacement batteries would not charge in my P1 Gen2 ThinkPad.
hello - 답글
Is it compatible for Lenovo Thinkpad P1 Gen1 Type 20MD ?
k2ki - 답글
댓글 쓰기
조회 통계:
24 시간 전: 19
7일 전: 73
30일 전: 355
전체 시간: 11,093
