소개
How to replace the battery of a Lenovo ThinkPad P1 Gen2 laptop. The images and information in this guide were taken from this computer's service manual.
필요한 것
Remove the 7 screws holding the base cover in place.
Remove the base cover.
Peel up the insulated sheet from the battery connector.
Unplug the battery connector in the direction showed by the arrow.
Remove the two M2 × L4 mm, flat-head screws.
Remove the two M2 × L5 mm, flat-head, screws.
To replace the battery & reassemble your device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
