주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad P50 Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad P50 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Slide the battery latch to the left to unlock it and remove the battery.
  2. Lenovo ThinkPad P50 Keyboard Replacement, Bottom case screws: 2 단계, 이미지 1개 중 1개
    • Loosen the six 12.6 mm captive screws that secure the lower case with the Phillips #00 screwdriver.
    • The screws will not come all the way out; do not attempt to remove them from the case.
    • Pull up the notch with your fingernail or a spudger.
  3. Lenovo ThinkPad P50 Keyboard Replacement, Bottom case: 3 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50 Keyboard Replacement, Bottom case: 3 단계, 이미지 2개 중 2개
    • Lift the lower case up and off of the chassis.
  4. Lenovo ThinkPad P50 Keyboard Replacement, Trackpad: 4 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50 Keyboard Replacement, Trackpad: 4 단계, 이미지 2개 중 2개
    • Remove the following screws with a Phillips #00 screwdriver:
    • Seven 5.7 mm screws
    • Five 4.3 mm screws
    • Three 12.6 mm screws
  5. Lenovo ThinkPad P50 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Turn the computer over and open the lid.
    • Insert an opening pick in the seam between the keyboard bezel and chassis.
    • Pry around the entire perimeter until the keyboard assembly fully releases.
  6. Lenovo ThinkPad P50 Keyboard Replacement: 6 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50 Keyboard Replacement: 6 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50 Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Pivot the keyboard further up until you can see the connectors on the underside of the keyboard
    • Detach the connectors that connect to the trackpad.
    • Most of the time, these connectors will have a lip or a tab along the top that can be used to push the connector out of its socket.
    • To disconnect, use the wide end of a spudger to push on the connector tab to slide it out of its socket.
    • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
  7. Lenovo ThinkPad P50 Keyboard Replacement, Keyboard: 7 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50 Keyboard Replacement, Keyboard: 7 단계, 이미지 2개 중 2개
    • Lift the keyboard slightly until you see the cable connection the keyboard to the rest of the computer
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
작성자
2다른 기여자 명과 함께
Sara Richardson
회원 가입일: 03/21/25
609 평판
안내서 5개를 작성함
UMass Dartmouth, Team 3-1, Botvin Spring 2025 UMass Dartmouth, Team 3-1, Botvin Spring 2025 회원
UMASSD-BOTVIN-S25S3G1
3 회원들
안내서 5개를 작성함
1가이드 댓글
This guide is woefully incorrect. You do not need to remove the palm rest in order to replace the keyboard. This is a great way to end up with a cracked palm rest if you're not careful. Please refer to the manufacturer's support guide here: Page 68 has the relevant material.
Shane Welsh - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 19
지난 30일: 91
전체 시간: 638
