주요 콘텐츠로 건너뛰기
Lenovo ThinkPad P50s Battery Pack Replacement
필요한 것
  1. Lenovo ThinkPad P50s Battery Pack Replacement, Battery: 1 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50s Battery Pack Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the device over so the bottom is facing you.
  2. Lenovo ThinkPad P50s Battery Pack Replacement: 2 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50s Battery Pack Replacement: 2 단계, 이미지 2개 중 2개
    • Use your thumb to slide the right lock switch button outward.
  3. Lenovo ThinkPad P50s Battery Pack Replacement: 3 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Battery Pack Replacement: 3 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Battery Pack Replacement: 3 단계, 이미지 3개 중 3개
    • With your thumb slide the left lock switch button outward while sliding the battery out with your other hand.
    • When replacing the battery, make sure that the connectors are aligned properly.
    • You may hear a click when the battery is fully seated and the lock engages.
  4. Lenovo ThinkPad P50s Battery Pack Replacement, Base Cover: 4 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50s Battery Pack Replacement, Base Cover: 4 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to unscrew the eight 2 mm captive screws.
    • These screws should not be removed entirely; you will be able to take off the base cover once they are loosened.
  5. Lenovo ThinkPad P50s Battery Pack Replacement: 5 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Battery Pack Replacement: 5 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Battery Pack Replacement: 5 단계, 이미지 3개 중 3개
    • With the plastic opening tool, pry up the base cover.
    • Slide the opening tool around the edge of the laptop to release the snap tabs.
    • You may need to use opening picks to hold the tabs apart, as the base is securely attached and tends to snap back into place.
  6. Lenovo ThinkPad P50s Battery Pack Replacement: 6 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50s Battery Pack Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the base cover off the laptop.
  7. Lenovo ThinkPad P50s Battery Pack Replacement, Battery Pack: 7 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Battery Pack Replacement, Battery Pack: 7 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Battery Pack Replacement, Battery Pack: 7 단계, 이미지 3개 중 3개
    • With your fingers or a spudger, disconnect the battery cable from the motherboard.
    • Use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
    • Don't push or pull on the cables themselves, or you may damage the connector.
  8. Lenovo ThinkPad P50s Battery Pack Replacement: 8 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the five 2.5 mm retaining screws.
  9. Lenovo ThinkPad P50s Battery Pack Replacement: 9 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50s Battery Pack Replacement: 9 단계, 이미지 2개 중 2개
    • Lift the battery away from the device to remove it.
결론
작성자
1다른 기여자 명과 함께
Jaylan
회원 가입일: 09/09/24
645 평판
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 15
전체 시간: 79
