주요 콘텐츠로 건너뛰기
Lenovo ThinkPad P50s Motherboard Replacement
필요한 것
  1. Lenovo ThinkPad P50s Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the device over so the bottom is facing you.
  2. Lenovo ThinkPad P50s Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Use your thumb to slide the right lock switch button outward.
  3. Lenovo ThinkPad P50s Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • With your thumb slide the left lock switch button outward while sliding the battery out with your other hand.
    • When replacing the battery, make sure that the connectors are aligned properly.
    • You may hear a click when the battery is fully seated and the lock engages.
  4. Lenovo ThinkPad P50s Motherboard Replacement, Base Cover: 4 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement, Base Cover: 4 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to unscrew the eight 2 mm captive screws.
    • These screws should not be removed entirely; you will be able to take off the base cover once they are loosened.
  5. Lenovo ThinkPad P50s Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • With the plastic opening tool, pry up the base cover.
    • Slide the opening tool around the edge of the laptop to release the snap tabs.
    • You may need to use opening picks to hold the tabs apart, as the base is securely attached and tends to snap back into place.
  6. Lenovo ThinkPad P50s Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the base cover off the laptop.
  7. Lenovo ThinkPad P50s Motherboard Replacement, Battery Pack: 7 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement, Battery Pack: 7 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Motherboard Replacement, Battery Pack: 7 단계, 이미지 3개 중 3개
    • With your fingers or a spudger, disconnect the battery cable from the motherboard.
    • Use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
    • Don't push or pull on the cables themselves, or you may damage the connector.
  8. Lenovo ThinkPad P50s Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the five 2.5 mm retaining screws.
  9. Lenovo ThinkPad P50s Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Lift the battery away from the device to remove it.
  10. Lenovo ThinkPad P50s Motherboard Replacement, Keyboard: 10 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement, Keyboard: 10 단계, 이미지 2개 중 2개
    • Use a spudger to push on the indents in the keyboard approximately 2.5 mm forward to reveal the 1.7 mm screws.
    • While the images show a metal spudger, you should avoid using one as it could damage the electronics of the device.
  11. Lenovo ThinkPad P50s Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws on the keyboard
    • Flip the keyboard forward to lie flat on the keys, exposing the two ribbons.
    • Be careful not to rip the ribbons when you flip the keyboard over.
  12. Lenovo ThinkPad P50s Motherboard Replacement: 12 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement: 12 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Motherboard Replacement: 12 단계, 이미지 3개 중 3개
    • Use a spudger or a clean fingernail to flip up the locking flap—this is the unlocked position.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers or your fingers to gently pull the cables out of their sockets.
    • If the cable has a pull tab, use it to grip the cable. You may damage the cable by gripping it directly.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
    • Remove the keyboard from the laptop.
  13. Lenovo ThinkPad P50s Motherboard Replacement, Fan assembly: 13 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement, Fan assembly: 13 단계, 이미지 2개 중 2개
    • Use the point of a spudger to push on alternating sides of the fan connector to "walk" it out of its socket.
  14. Lenovo ThinkPad P50s Motherboard Replacement: 14 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement: 14 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Motherboard Replacement: 14 단계, 이미지 3개 중 3개
    • Use the opening tool to lift up the locking flap on the power button cable.
    • Use tweezers or your fingers to gently pull the cable out of its socket.
  15. Lenovo ThinkPad P50s Motherboard Replacement: 15 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement: 15 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Motherboard Replacement: 15 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to loosen the seven 2.5 mm captive screws securing the fan assembly to the motherboard.
  16. Lenovo ThinkPad P50s Motherboard Replacement: 16 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement: 16 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Motherboard Replacement: 16 단계, 이미지 3개 중 3개
    • Gently peel back the power button cable.
  17. Lenovo ThinkPad P50s Motherboard Replacement: 17 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement: 17 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Motherboard Replacement: 17 단계, 이미지 3개 중 3개
    • Lift the fan off the board to remove it.
  18. Lenovo ThinkPad P50s Motherboard Replacement, Motherboard: 18 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement, Motherboard: 18 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Motherboard Replacement, Motherboard: 18 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to lift the locking pad on the trackpad cable connector to the unlocked position.
  19. Lenovo ThinkPad P50s Motherboard Replacement: 19 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement: 19 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Motherboard Replacement: 19 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to lift the locking pad on the fingerprint cable.
  20. Lenovo ThinkPad P50s Motherboard Replacement: 20 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement: 20 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Motherboard Replacement: 20 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the single 2.5 mm screw securing the WLAN card.
    • Slide the WLAN card out of its socket.
    • When replacing the WLAN card, carefully align the connecting pins with the socket to prevent damage.
  21. Lenovo ThinkPad P50s Motherboard Replacement: 21 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement: 21 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Motherboard Replacement: 21 단계, 이미지 3개 중 3개
    • Use the opening tool to lift the locking flap on the LCD cable connector.
    • Use tweezers or your fingers to gently pull the LCD cable out of its socket.
  22. Lenovo ThinkPad P50s Motherboard Replacement: 22 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement: 22 단계, 이미지 2개 중 2개
    • Pull the DC-in cable connector out with your fingers. If you aren't able to pull it by the connector, use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket.
    • Don't push on the cables themselves, or you may damage the connector.
  23. Lenovo ThinkPad P50s Motherboard Replacement: 23 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement: 23 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Motherboard Replacement: 23 단계, 이미지 3개 중 3개
    • Use the point of a spudger to push on alternating sides of the speaker assembly cable connector to remove it from its socket.
    • Don't pull on the cables as this may cause damage.
  24. Lenovo ThinkPad P50s Motherboard Replacement: 24 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the five 2.5 mm screws securing the motherboard to the chassis.
  25. Lenovo ThinkPad P50s Motherboard Replacement: 25 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50s Motherboard Replacement: 25 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50s Motherboard Replacement: 25 단계, 이미지 3개 중 3개
    • Remove the motherboard from the laptop.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
작성자
1다른 기여자 명과 함께
Jaylan
회원 가입일: 09/09/24
645 평판
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 62
