주요 콘텐츠로 건너뛰기
Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement
필요한 것
  1. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, Hard Disk Drive: 1 단계, 이미지 1/2 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, Hard Disk Drive: 1 단계, 이미지 2/2
    • Remove the 8 screws that hold down the back panel using the Phillips #000 screwdriver.
  2. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 2 단계, 이미지 1/1
    • Remove the two M2 x 3 mm, wafer-head, nylon-coated screws that hold down the hard drive assembly using the Phillips #0 screwdriver.
  3. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 3 단계, 이미지 1/1
    • Pull the hard drive assembly out with backside up.
  4. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 4 단계, 이미지 1/1
    • Remove the four M3 x 3 mm, flat-head, nylon-coated screws on the side of the hard drive assembly using the Phillips #0 screwdriver.
  5. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 5 단계, 이미지 1/1
    • Gently, remove the plastic cover with the blue strips.
  6. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, HDMI-USB Jack assembly: 6 단계, 이미지 1/2 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, HDMI-USB Jack assembly: 6 단계, 이미지 2/2
    • Remove the 3 screws holding down the T shaped cover using the Phillips head #1. Two of the screws are M2.5x 4 wafer head. The other is a M2x4MM.
    • The two similar screws have blue threading around them.
  7. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 7 단계, 이미지 1/2 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 7 단계, 이미지 2/2
    • Use the opening tool to lift up the T shaped cover.
    • Remove the M2x3MM wafer head screw.
  8. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 8 단계, 이미지 1/3 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 8 단계, 이미지 2/3 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 8 단계, 이미지 3/3
    • Take off the 2 M2x3MM wafered screws holding down the chip top of assembly.
    • Lift the chip to release the HDMI-USB jack assembly
  9. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: 9 단계, 이미지 1/1
    • Detach the connector.
결론
Mohammed AlManai
회원 가입일: 04/05/18
648 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 8
전체 시간: 295
