소개
This guide will show you the steps to safely remove the damaged integrated camera from your laptop. The integrated camera is located above the screen of your laptop, which is usually used to take pictures, create videos, and chat with others.
필요한 것
Unplug the connector. It is located on the top of the screen attached to the camera assembly.
이 단계에 사용된 도구:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Use the 3.0 flathead to lift up the silver camera strip.
다른 2명이 해당 안내서를 완성하였습니다.
