주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement
필요한 것
  1. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 1개 Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 2개
    • For your safety, discharge your battery below 25% before disassembling your laptop. A charged battery may catch fire if damaged. If your battery is swollen, take appropriate precautions.
    • Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
  2. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Loosen the base cover screws: 2 단계, 이미지 2개 중 1개 Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Loosen the base cover screws: 2 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
  3. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Remove the base cover: 3 단계, 이미지 3개 중 1개 Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Remove the base cover: 3 단계, 이미지 3개 중 2개 Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Remove the base cover: 3 단계, 이미지 3개 중 3개
    • The base cover is still lightly clipped to the laptop.
    • Use your fingers to grab and lift the top-right corner of the base cover near the hinge.
    • Repeat at the top-left corner.
  4. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement: 4 단계, 이미지 3개 중 1개 Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement: 4 단계, 이미지 3개 중 2개 Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement: 4 단계, 이미지 3개 중 3개
    • Slowly lift the hinge edge of the base cover until the remaining clips release.
    • Remove the base cover.
    • During reassembly, align the base cover's bottom edge tabs with the laptop, then lay the cover in place. Press around the perimeter to clip the base cover to the laptop.
  5. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Disconnect the battery: 5 단계, 이미지 3개 중 1개 Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Disconnect the battery: 5 단계, 이미지 3개 중 2개 Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Disconnect the battery: 5 단계, 이미지 3개 중 3개
    • Use your fingers to squeeze the two latches on either side of the battery connector.
    • While squeezing the latches, lift the top edge of the battery up.
  6. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Remove the battery: 6 단계, 이미지 2개 중 1개 Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Remove the battery: 6 단계, 이미지 2개 중 2개
    • Remove the battery.
  7. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Remove the LPCAMM2 cover: 7 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to loosen the three captive screws securing the LPCAMM2 cover.
    • During reassembly, tighten the screws in the order printed on the cover.
  8. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement: 8 단계, 이미지 2개 중 1개 Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement: 8 단계, 이미지 2개 중 2개
    • Lift and remove the LPCAMM2 cover.
  9. Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Remove the LPCAMM2 memory: 9 단계, 이미지 2개 중 1개 Lenovo ThinkPad T14 Gen 7 LPCAMM2 Memory Replacement, Remove the LPCAMM2 memory: 9 단계, 이미지 2개 중 2개
    • Grab the edges of the LPCAMM2 memory module and lift straight up to remove it.
    • Avoid touching the gold underside of the module—your skin oils can interfere with the electrical contacts. If you touch it by accident and plan to re-use it, clean it with high-concentration isopropyl alcohol (>90%) and a lint-free cloth before reinstalling it.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
334,236 평판
안내서 847개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 102
지난 30일: 516
전체 시간: 2,869
