주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T400 Hard Drive Replacement
필요한 것
  1. Lenovo ThinkPad T400 Hard Drive Replacement, Hard drive: 1 단계, 이미지 1/1
    • Safe Shutdown: Press the "Windows" button and select "Shut down" or simply turn off the power, by pressing the power button for about 3-5 seconds until the screen completely turns off.
    • If your system is working now, please make sure to save all of files while in progress.
    • With a force shutdown, the work that hasn't been saved can be lost.
  2. Lenovo ThinkPad T400 Hard Drive Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad T400 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Remove the power cord.
    • Using the switch on the battery, slide and pull to remove it.
  3. Lenovo ThinkPad T400 Hard Drive Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad T400 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Using a flathead screwdriver, remove the two screws that are holding the hard drive cover in place on the back corner of the computer.
  4. Lenovo ThinkPad T400 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Use a flathead screwdriver to gently pry up the cover and remove it completely.
  5. Lenovo ThinkPad T400 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Use the pull tab on the hard drive to completely pull out the hard drive. Please pull out slowly and gently.
  6. Lenovo ThinkPad T400 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Using a #00 Phillips head screwdriver, remove all four screws on the hard drive cover.
  7. Lenovo ThinkPad T400 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Remove the side bumpers from the original hard drive and place them on the new hard drive.
  8. Lenovo ThinkPad T400 Hard Drive Replacement: 8 단계, 이미지 1/1
    • Snap cover onto the new hard driver and tighten the four screws with a #00 Phillips head screwdriver. Then insert it back into the computer.
    • Make sure the black tab is facing out, like when it was removed.
  9. Lenovo ThinkPad T400 Hard Drive Replacement: 9 단계, 이미지 1/1
    • Put cover back on computer and tighten screws with a flathead screw driver.
결론
At the end of this fix, you can plug in your computer/ attach battery and turn on the computer.
다른 5명이 해당 안내서를 완성하였습니다.
Tanner Therrien
회원 가입일: 06/20/18
289 평판
안내서 1개 작성함
Washington State, Team S1-G3, Hope Summer 2018 Washington State, Team S1-G3, Hope Summer 2018 회원
WSU-HOPE-SU18S1G3
3 회원들
안내서 1개 작성하였습니다
댓글 2개
OK thru Step 5. Then, the Phillips screws are neither visible nor accessible until after the side bumpers have been removed. Likewise, the side bumper replacement must be the last thing done before the drive re-insertion. A small nit-pik for an otherwise clear and helpful procedure. Thanks!
cyanth - 답글
thank you for this, much easier than expected even for me…
mridgway89 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 24
30일 전: 74
전체 시간: 9,569
