소개
This repair guide provide information on how to replace the Lenovo ThinkPad T400 hard drive replacement problem. Not much computer repair experience is needed for this fix. It is relatively simple and easy to follow these simple steps.
필요한 것
Safe Shutdown: Press the "Windows" button and select "Shut down" or simply turn off the power, by pressing the power button for about 3-5 seconds until the screen completely turns off.
At the end of this fix, you can plug in your computer/ attach battery and turn on the computer.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 2개
OK thru Step 5. Then, the Phillips screws are neither visible nor accessible until after the side bumpers have been removed. Likewise, the side bumper replacement must be the last thing done before the drive re-insertion. A small nit-pik for an otherwise clear and helpful procedure. Thanks!
thank you for this, much easier than expected even for me…
mridgway89 - 답글
