주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T400s Heatsink & Fan Replacement
필요한 것
  1. Lenovo ThinkPad T400s Heatsink & Fan Replacement, Keyboard: 1 단계, 이미지 1/2 Lenovo ThinkPad T400s Heatsink & Fan Replacement, Keyboard: 1 단계, 이미지 2/2
    • Remove the Phillips #0-6mm screw.
    • Lift up the back cover to the RAM cards.
  2. Lenovo ThinkPad T400s Heatsink & Fan Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad T400s Heatsink & Fan Replacement: 2 단계, 이미지 2/2
    • Pull the lock for the baterry to the left to unlock.
    • While holding the tab in the unlocked position, remove the battery.
  3. Lenovo ThinkPad T400s Heatsink & Fan Replacement: 3 단계, 이미지 1/1
    • Remove the three Phillips #0-6mm screws on the back panel.
    • These screws are marked with a keyboard symbol next to them.
  4. Lenovo ThinkPad T400s Heatsink & Fan Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad T400s Heatsink & Fan Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad T400s Heatsink & Fan Replacement: 4 단계, 이미지 3/3
    • Turn the computer over and open the lid.
    • Wedge the small metal spudger between the palm rest and the keyboard.
  5. Lenovo ThinkPad T400s Heatsink & Fan Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad T400s Heatsink & Fan Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad T400s Heatsink & Fan Replacement: 5 단계, 이미지 3/3
    • Lift up the keyboard, but be careful not to completely remove.
    • Don't lift the keyboard too quickly, there is a connector cable you must disconnect first.
    • Wedge the small plastic opening tool underneath copper band and tilt back.
    • Remove keyboard to replace.
  6. Lenovo ThinkPad T400s Heatsink & Fan Replacement, Heatsink/Fan: 6 단계, 이미지 1/1
    • Remove the 7 Phillips#0-4mm screws.
  7. Lenovo ThinkPad T400s Heatsink & Fan Replacement: 7 단계, 이미지 1/1
    • Remove the SSD/HDD cover from the lower right corner of the laptop.
  8. Lenovo ThinkPad T400s Heatsink & Fan Replacement: 8 단계, 이미지 1/1
    • Remove the nine Phillips #0-6mm screws on the back panel.
  9. Lenovo ThinkPad T400s Heatsink & Fan Replacement: 9 단계, 이미지 1/2 Lenovo ThinkPad T400s Heatsink & Fan Replacement: 9 단계, 이미지 2/2
    • Pull up on the unlock button while pushing left on the sliding tab.
    • Do not be discouraged if it takes some force.
  10. Lenovo ThinkPad T400s Heatsink & Fan Replacement: 10 단계, 이미지 1/2 Lenovo ThinkPad T400s Heatsink & Fan Replacement: 10 단계, 이미지 2/2
    • Use the plastic opening tool to lift the black tab up and remove the palm rest connection.
    • Remove the palm rest by lifting the side nearest to you.
  11. Lenovo ThinkPad T400s Heatsink & Fan Replacement: 11 단계, 이미지 1/2 Lenovo ThinkPad T400s Heatsink & Fan Replacement: 11 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Rotate the laptop 90 degrees counter-clockwise.
    • Remove the safety screw on the bottom corner of the laptop by holding the gold cap in place with the tweezers and unscrewing the Phillips screw with the other hand.
  12. Lenovo ThinkPad T400s Heatsink & Fan Replacement: 12 단계, 이미지 1/2 Lenovo ThinkPad T400s Heatsink & Fan Replacement: 12 단계, 이미지 2/2
    • Flip the computer over and open the lid. Unscrew the seven Phillips#0-4mm screws.
    • Lift the frame up by the front and pull towards you to remove.
  13. Lenovo ThinkPad T400s Heatsink & Fan Replacement: 13 단계, 이미지 1/2 Lenovo ThinkPad T400s Heatsink & Fan Replacement: 13 단계, 이미지 2/2
    • Remove the two Phillips #0-6.5mm screws from the back side of the laptop to detach the screen.
    • Lift the laptop down facing you, and place the screen down flat behind the laptop.
    • The screen will still be connected to the base by wires.
  14. Lenovo ThinkPad T400s Heatsink & Fan Replacement: 14 단계, 이미지 1/1
    • Remove the eight Phillips #0-3mm screws.
    • Remove the two Phillips #0-6mm screws.
    • The circuit board will still be attached by the colored wires.
  15. Lenovo ThinkPad T400s Heatsink & Fan Replacement: 15 단계, 이미지 1/2 Lenovo ThinkPad T400s Heatsink & Fan Replacement: 15 단계, 이미지 2/2
    • Tilt up the circuit board to access the heatsink and fan.
    • Disconnect the white connector to remove.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Matthew Lee
회원 가입일: 04/14/15
247 평판
안내서 1개 작성함
Cal Poly, Team 6-18, Maness Spring 2015 Cal Poly, Team 6-18, Maness Spring 2015 회원
CPSU-MANESS-S15S6G18
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 3,576
