주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T400s Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad T400s Keyboard Replacement, Keyboard: 1 단계, 이미지 1/2 Lenovo ThinkPad T400s Keyboard Replacement, Keyboard: 1 단계, 이미지 2/2
    • Remove the Phillips #0-6mm screw.
    • Lift up the back cover to the RAM cards.
  2. Lenovo ThinkPad T400s Keyboard Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad T400s Keyboard Replacement: 2 단계, 이미지 2/2
    • Pull the lock for the baterry to the left to unlock.
    • While holding the tab in the unlocked position, remove the battery.
  3. Lenovo ThinkPad T400s Keyboard Replacement: 3 단계, 이미지 1/1
    • Remove the three Phillips #0-6mm screws on the back panel.
    • These screws are marked with a keyboard symbol next to them.
  4. Lenovo ThinkPad T400s Keyboard Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad T400s Keyboard Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad T400s Keyboard Replacement: 4 단계, 이미지 3/3
    • Turn the computer over and open the lid.
    • Wedge the small metal spudger between the palm rest and the keyboard.
  5. Lenovo ThinkPad T400s Keyboard Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad T400s Keyboard Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad T400s Keyboard Replacement: 5 단계, 이미지 3/3
    • Lift up the keyboard, but be careful not to completely remove.
    • Don't lift the keyboard too quickly, there is a connector cable you must disconnect first.
    • Wedge the small plastic opening tool underneath copper band and tilt back.
    • Remove keyboard to replace.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Morgan Montalvo
회원 가입일: 04/14/15
652 평판
안내서 3개 작성하였습니다
Cal Poly, Team 6-18, Maness Spring 2015 Cal Poly, Team 6-18, Maness Spring 2015 회원
CPSU-MANESS-S15S6G18
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 1,501
