주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T400s LCD Screen Replacement
필요한 것
  1. Lenovo ThinkPad T400s LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/1
    • Use a #0 Phillips head screwdriver to remove the two 3mm screws that hold the screen bezel in place.
  2. Lenovo ThinkPad T400s LCD Screen Replacement: 2 단계, 이미지 1/1
    • Using the plastic opening tool, gently pry off the plastic LCD screen frame around the entire perimeter.
    • Be careful while prying the frame off, because the plastic tabs that hold it in may break.
  3. Lenovo ThinkPad T400s LCD Screen Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad T400s LCD Screen Replacement: 3 단계, 이미지 2/2
    • Remove the LCD connector by pulling on the ribbon cable at the connection.
  4. Lenovo ThinkPad T400s LCD Screen Replacement: 4 단계, 이미지 1/1
    • Lift the LCD screen out to replace.
    • Make sure to remove the screen with both hands and from opposite edges of the screen.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Christopher Noone
회원 가입일: 04/14/15
235 평판
안내서 1개 작성함
Cal Poly, Team 6-18, Maness Spring 2015 Cal Poly, Team 6-18, Maness Spring 2015 회원
CPSU-MANESS-S15S6G18
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 14
전체 시간: 2,605
