이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Is your ThinkPad not able to read DVD's? Or maybe the drive itself won't open. Here is a guide to diagnose any of these problems. Usually, the problem is either the drive tray or the motor. In order to fix those, you will need to use this guide to remove the DVD drive.
Flip the laptop over.
Push and hold the locking switch to the left.
Pull the battery out with your other hand.
다른 한 분이 해당 안내서를 완성하였습니다.
