주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T410s Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad T410s Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over.
    • Push and hold the locking switch to the left.
    • Pull the battery out with your other hand.
  2. Lenovo ThinkPad T410s Keyboard Replacement, RAM: 2 단계, 이미지 1/2 Lenovo ThinkPad T410s Keyboard Replacement, RAM: 2 단계, 이미지 2/2
    • Remove the single Phillips #0 screw grin the back panel.
    • Pull the back panel off.
  3. Lenovo ThinkPad T410s Keyboard Replacement: 3 단계, 이미지 1/3 Lenovo ThinkPad T410s Keyboard Replacement: 3 단계, 이미지 2/3 Lenovo ThinkPad T410s Keyboard Replacement: 3 단계, 이미지 3/3
    • Pull the metal prongs at the side of the RAM away from each other.
    • The RAM will pop out of its socket when done correctly.
    • Pull the RAM out.
  4. Lenovo ThinkPad T410s Keyboard Replacement, Hard Drive: 4 단계, 이미지 1/2 Lenovo ThinkPad T410s Keyboard Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Remove the single Phillips #0 screw that secures the hard drive cover.
  5. Lenovo ThinkPad T410s Keyboard Replacement: 5 단계, 이미지 1/2 Lenovo ThinkPad T410s Keyboard Replacement: 5 단계, 이미지 2/2
    • Flip the black plastic tab out.
  6. Lenovo ThinkPad T410s Keyboard Replacement: 6 단계, 이미지 1/2 Lenovo ThinkPad T410s Keyboard Replacement: 6 단계, 이미지 2/2
    • Pull the hard drive out.
  7. Lenovo ThinkPad T410s Keyboard Replacement, Keyboard: 7 단계, 이미지 1/1
    • Remove the Flathead 2.5mm screw.
  8. Lenovo ThinkPad T410s Keyboard Replacement: 8 단계, 이미지 1/2 Lenovo ThinkPad T410s Keyboard Replacement: 8 단계, 이미지 2/2
    • Wedge the flat end of a spudger, or plastic opening tool, under the end of the keyboard and pry up.
  9. Lenovo ThinkPad T410s Keyboard Replacement: 9 단계, 이미지 1/2 Lenovo ThinkPad T410s Keyboard Replacement: 9 단계, 이미지 2/2
    • Slide the keyboard out of the way until you can see what's underneath it.
    • The keyboard is still attached with a ribbon cable so don't try to fully remove it.
  10. Lenovo ThinkPad T410s Keyboard Replacement: 10 단계, 이미지 1/1
    • Use the flat end of a spudger to unplug the keyboard connector from the laptop.
    • Pull the keyboard out.
결론
Blake Wilson
회원 가입일: 02/21/18
117 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 41
전체 시간: 2,808
