주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T420s Hard Disk Drive Replacement
필요한 것
  1. Lenovo ThinkPad T420s Hard Disk Drive Replacement, Hard Disk Drive: 1 단계, 이미지 1/2 Lenovo ThinkPad T420s Hard Disk Drive Replacement, Hard Disk Drive: 1 단계, 이미지 2/2
    • Turn the laptop upside down.
  2. Lenovo ThinkPad T420s Hard Disk Drive Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad T420s Hard Disk Drive Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to unscrew and remove the screw on the hard drive compartment at the bottom right of the device.
  3. Lenovo ThinkPad T420s Hard Disk Drive Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad T420s Hard Disk Drive Replacement: 3 단계, 이미지 2/2
    • Pull the hard driver compartment cover up, then out by pulling on the edge near the screw hole.
  4. Lenovo ThinkPad T420s Hard Disk Drive Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad T420s Hard Disk Drive Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad T420s Hard Disk Drive Replacement: 4 단계, 이미지 3/3
    • Pull the hard drive out of the hard drive compartment.
  5. Lenovo ThinkPad T420s Hard Disk Drive Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad T420s Hard Disk Drive Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad T420s Hard Disk Drive Replacement: 5 단계, 이미지 3/3
    • Pull the red rails off both sides of the hard drive.
    • The red rails will be put back on the new hard drive that you install.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Parker Wiley
회원 가입일: 02/21/22
178 평판
안내서 1개 작성함
University of North Texas, Team 1-2, Smith Spring 2022 University of North Texas, Team 1-2, Smith Spring 2022 회원
UNT-SMITH-S22S1G2
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 59
전체 시간: 1,375
