주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T420s Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad T420s Keyboard Replacement, Keyboard: 1 단계, 이미지 1/2 Lenovo ThinkPad T420s Keyboard Replacement, Keyboard: 1 단계, 이미지 2/2
    • Flip your laptop over so the bottom is facing up.
    • Remove the memory panel by removing two black 5mm screws using the Phillips #0.
    • Remove the memory panel.
  2. Lenovo ThinkPad T420s Keyboard Replacement: 2 단계, 이미지 1/1
    • Remove the two 5mm screw using the Phillips #0 screwdriver.
    • Flip the laptop back over and open it.
  3. Lenovo ThinkPad T420s Keyboard Replacement: 3 단계, 이미지 1/3 Lenovo ThinkPad T420s Keyboard Replacement: 3 단계, 이미지 2/3 Lenovo ThinkPad T420s Keyboard Replacement: 3 단계, 이미지 3/3
    • Gently push down on the keyboard and slide it towards the screen. This will pop the bottom of the keyboard out of the casing.
    • The best place to push is on the frame of the keyboard by the power button.
    • Using the metal spudger, lift and slide out the keyboard.
    • When lifting the keyboard do not remove it completely because a cable will still be connected to the laptop.
  4. Lenovo ThinkPad T420s Keyboard Replacement: 4 단계, 이미지 1/1
    • Remove the orange cable by lifting up on the tab on the end of the ribbon connection.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Alex Cabrera
회원 가입일: 04/14/15
653 평판
안내서 2개 작성하였습니다
Cal Poly, Team 6-13, Maness Spring 2015 Cal Poly, Team 6-13, Maness Spring 2015 회원
CPSU-MANESS-S15S6G13
4 회원들
안내서 5개 작성하였습니다
댓글 6개
This is not the Lenovo Thinkpad T420. You can Tell by the RAM memory Slot Cover and the Position the RAM is put into its slot. the T420 RAM is Vertical Compared with being Horizontal in this Picture. that includes the cover also. Then the Battery Slot is a Dead Giveaway clue. The T420 Battery slot is in the middle. and this Picture has the battery slot to bthe left. Sorry Not Even Close. None of the screws he removes are on the T420. so this is Completely Useless. Thanks
Keith Cloward - 답글
The steps are almost exactly the same though - I've performed them on my own T420. This guide is for the T420s. Just remove the memory panel with the single screw on the base of the laptop, remove the screw with the keyboard emblem next to it, and follow the keyboard removal steps in this guide.
Toby Jones -
you do know this guide was made for the T420s? it literally says so on the guide. take a moment to read my friend.
the bongo guy -
I just did this, in combination with this: https://support.lenovo.com/us/en/solutio...
Was pretty easy and working great. I am bit intimidated opening up a laptop or PC, but the “Easy” rating on this gave me the idea to try. Glad I did.
Jay Stokes - 답글
Thanks for your post Jay, the link was not valid any more but i went on that site and looked for the correct Maintenance Manual which helped me complement this guide while changing my keyboard. Here everyone with Lenovos can get this kind of Manuals which are official, very complete, and explanatory with good graphics of the procedures and parts: https://download.lenovo.com/eol/index.ht...
Javier -
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 76
전체 시간: 33,669
