주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T430s RAM Stick Replacement
필요한 것
  1. Lenovo ThinkPad T430s RAM Stick Replacement, Battery: 1 단계, 이미지 1/3 Lenovo ThinkPad T430s RAM Stick Replacement, Battery: 1 단계, 이미지 2/3 Lenovo ThinkPad T430s RAM Stick Replacement, Battery: 1 단계, 이미지 3/3
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s RAM Stick Replacement, RAM Stick: 2 단계, 이미지 1/3 Lenovo ThinkPad T430s RAM Stick Replacement, RAM Stick: 2 단계, 이미지 2/3 Lenovo ThinkPad T430s RAM Stick Replacement, RAM Stick: 2 단계, 이미지 3/3
    • With the Phillips #0 screwdriver, loosen the two 30 mm screws holding down the RAM stick plate.
    • Pry up the plate and set it aside.
  3. Lenovo ThinkPad T430s RAM Stick Replacement: 3 단계, 이미지 1/3 Lenovo ThinkPad T430s RAM Stick Replacement: 3 단계, 이미지 2/3 Lenovo ThinkPad T430s RAM Stick Replacement: 3 단계, 이미지 3/3
    • Use the pointy end of the spudger to bend the bars holding the RAM stick in place.
    • Lift the RAM stick up and out of the stick holder.
결론
Melissa Rogers
회원 가입일: 09/02/20
681 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 33
전체 시간: 877
