주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T431S Battery Replacement
필요한 것
  1. Lenovo ThinkPad T431S Battery Replacement, Battery: 1 단계, 이미지 1/2 Lenovo ThinkPad T431S Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Remember, to prevent electric shock or harm, disconnect the laptop from any external power source and make sure device is powered off before starting any disassembly.
    • Use a Phillips #1 screwdriver bit to remove the eight 5mm screws from the back panel.
    • Once the screws are loose, use the three opening tools to loosen and remove the back panel.
  2. Lenovo ThinkPad T431S Battery Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T431S Battery Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T431S Battery Replacement: 2 단계, 이미지 3/3
    • Carefully unplug the battery cable from the connector on the motherboard, using your fingers to pull the cable straight out of the port.
  3. Lenovo ThinkPad T431S Battery Replacement: 3 단계, 이미지 1/3 Lenovo ThinkPad T431S Battery Replacement: 3 단계, 이미지 2/3 Lenovo ThinkPad T431S Battery Replacement: 3 단계, 이미지 3/3
    • Unscrew the five 4mm screws that are holding the battery secure with a Phillips #1 screwdriver.
    • Remove the Li-polymer battery by lifting it directly out of the device.
    • Information about disposal of your damaged battery can be found at E-Waste Recycling
결론
다른 3명이 해당 안내서를 완성하였습니다.
Christine Portanova
회원 가입일: 01/30/20
522 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 20
전체 시간: 1,275
