주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T431S Charging Port Replacement
필요한 것
  1. Lenovo ThinkPad T431S Charging Port Replacement, Charging Port: 1 단계, 이미지 1/2 Lenovo ThinkPad T431S Charging Port Replacement, Charging Port: 1 단계, 이미지 2/2
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
    • After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
  2. Lenovo ThinkPad T431S Charging Port Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad T431S Charging Port Replacement: 2 단계, 이미지 2/2
    • Unscrew the single, 3.0 mm screw with a Phillips #1 screwdriver bit that holds the charging port housing into place.
  3. Lenovo ThinkPad T431S Charging Port Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad T431S Charging Port Replacement: 3 단계, 이미지 2/2
    • Remove the small, white connector cable by prying it from the connector with a plastic opening tool.
    • Remove the charging port assembly.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Christine Portanova
회원 가입일: 01/30/20
522 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 22
전체 시간: 4,056
