주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T431S Fan Replacement
필요한 것
  1. Lenovo ThinkPad T431S Fan Replacement, Fan: 1 단계, 이미지 1/2 Lenovo ThinkPad T431S Fan Replacement, Fan: 1 단계, 이미지 2/2
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
    • Carefully pry off the back panel using the opening tool.
  2. Lenovo ThinkPad T431S Fan Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad T431S Fan Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver bit and remove the four 3.0 mm screws from the heatsink.
  3. Lenovo ThinkPad T431S Fan Replacement: 3 단계, 이미지 1/3 Lenovo ThinkPad T431S Fan Replacement: 3 단계, 이미지 2/3 Lenovo ThinkPad T431S Fan Replacement: 3 단계, 이미지 3/3
    • Disconnect the cable attached to the fan, pulling the connector straight down.
    • Lift and remove the fan.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Joe Minnich
회원 가입일: 01/30/20
187 평판
안내서 1개 작성함
댓글 한 개
Well done. I will have a go at fixing the fan on my T430s now that I’ve seen how easy it is to do.
Jocko - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 358
