주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T431S Hard Drive Replacement
필요한 것
  1. Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/3 Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/3 Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3/3
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect the laptop from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver to remove the eight 5.0 mm screws from the panel.
    • After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
  2. Lenovo ThinkPad T431S Hard Drive Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T431S Hard Drive Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T431S Hard Drive Replacement: 2 단계, 이미지 3/3
    • Remove the single 3 mm screw holding hard drive bracket in place.
    • Grasp the hard drive and remove it from its bracket.
    • Use a slight wiggle motion to carefully disconnect it from the front prong.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Christine Portanova
회원 가입일: 01/30/20
522 평판
안내서 4개 작성하였습니다
댓글 한 개
Can I add SSD without removing HDD? in Lenovo T431s?
Usama Khan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 17
전체 시간: 631
