주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T431S Screen Replacement
필요한 것
  1. Lenovo ThinkPad T431S Screen Replacement, Screen: 1 단계, 이미지 1/2 Lenovo ThinkPad T431S Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use the Jimmy tool to remove the screen bezel with a gentle prying motion.
  2. Lenovo ThinkPad T431S Screen Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad T431S Screen Replacement: 2 단계, 이미지 2/2
    • Remove the four 3.0 mm screws in the four corners of the screen with a Phillips #1 screwdriver bit.
    • While removing the screws, pry the screen off with an opening tool.
    • If your screen is cracked, use caution, as there will be broken glass or sharp parts.
  3. Lenovo ThinkPad T431S Screen Replacement: 3 단계, 이미지 1/3 Lenovo ThinkPad T431S Screen Replacement: 3 단계, 이미지 2/3 Lenovo ThinkPad T431S Screen Replacement: 3 단계, 이미지 3/3
    • Lift screen off of top panel to reveal LCD power plug/connector.
    • There will be a wire attaching the screen to the rest of the device.
    • Remove the tape on the wire so you can unplug the connection, pulling upwards.
    • Information about disposal of your damaged screen can be found at E-Waste Recycling
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Christine Portanova
회원 가입일: 01/30/20
522 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 944
