소개
The back cover is the protective layer for your computer that covers many components that will likely be replaced. The process is very simple and you will only need to remove two screws with a Phillips #1 screw driver.
필요한 것
Use a Phillips #1 screwdriver to remove the two 8mm screws holding the back cover.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
