주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T440p Display Replacement
필요한 것
  1. Lenovo ThinkPad T440p Display Replacement, Display: 1 단계, 이미지 1/2 Lenovo ThinkPad T440p Display Replacement, Display: 1 단계, 이미지 2/2
    • Flip the laptop over so that the bottom of the laptop is facing you.
  2. Lenovo ThinkPad T440p Display Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad T440p Display Replacement: 2 단계, 이미지 2/2
    • Slide each of the battery latches away from each other into the unlocked location.
  3. Lenovo ThinkPad T440p Display Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad T440p Display Replacement: 3 단계, 이미지 2/2
    • Slide the battery out of the battery compartment.
  4. Lenovo ThinkPad T440p Display Replacement: 4 단계, 이미지 1/2 Lenovo ThinkPad T440p Display Replacement: 4 단계, 이미지 2/2
    • Flip the laptop over so that the top of the laptop faces you.
  5. Lenovo ThinkPad T440p Display Replacement: 5 단계, 이미지 1/2 Lenovo ThinkPad T440p Display Replacement: 5 단계, 이미지 2/2
    • Lift the lid of the laptop until the top of the lid is touching the ground.
  6. Lenovo ThinkPad T440p Display Replacement: 6 단계, 이미지 1/3 Lenovo ThinkPad T440p Display Replacement: 6 단계, 이미지 2/3 Lenovo ThinkPad T440p Display Replacement: 6 단계, 이미지 3/3
    • Carefully pry the display bezels away from the display using the plastic opening tool.
    • The edges on the underside of the bezel that touches the display may be sharp.
  7. Lenovo ThinkPad T440p Display Replacement: 7 단계, 이미지 1/2 Lenovo ThinkPad T440p Display Replacement: 7 단계, 이미지 2/2
    • Use the Phillips #0 screwdriver to remove the four 3mm display screws.
  8. Lenovo ThinkPad T440p Display Replacement: 8 단계, 이미지 1/1
    • Carefully lift the display up and place it on the keyboard.
    • Don't remove it from the laptop. There's a cable still attached to it.
  9. Lenovo ThinkPad T440p Display Replacement: 9 단계, 이미지 1/3 Lenovo ThinkPad T440p Display Replacement: 9 단계, 이미지 2/3 Lenovo ThinkPad T440p Display Replacement: 9 단계, 이미지 3/3
    • Locate the latch attached to the display cable.
    • Grab the latch and flip it over so that it is facing away from you.
  10. Lenovo ThinkPad T440p Display Replacement: 10 단계, 이미지 1/1
    • Gently remove the cable from the display by pulling it directly away from you.
  11. Lenovo ThinkPad T440p Display Replacement: 11 단계, 이미지 1/2 Lenovo ThinkPad T440p Display Replacement: 11 단계, 이미지 2/2
    • Remove the display from the computer.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Rasheed Adam
회원 가입일: 07/27/20
337 평판
안내서 1개 작성함
UW Tacoma, Team S1-G19, Cardinal Summer 2020 UW Tacoma, Team S1-G19, Cardinal Summer 2020 회원
UWT-CARDINAL-SU20S1G19
1 회원
안내서 1개 작성하였습니다
댓글 2개
Easy peasy! Got a fresh 1080p IPS display into my ThinkPad thanks to this guide!
Noah - 답글
What display did you have before? I have heard that there are two different display cables and if you didn't already have a 900p screen/already had a 768p screen, then you will need a new display cable to do the FHD display swap.
Annika Genisis -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 64
전체 시간: 3,195
