소개
The hard drive is primarily used for the Lenovo ThinkPad T440p’s storage. If your computer is slow, it most likely needs replacing. The replacement is simple and will only require unscrewing screws and using a spudger to lift the hard drive out.
필요한 것
Use a Phillips #1 screwdriver to remove the two 8mm screws holding the back cover.
거의 끝나갑니다!
결론
다른 8명이 해당 안내서를 완성하였습니다.
