주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T440p Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad T440p Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop so that the back is facing up.
  2. Lenovo ThinkPad T440p Keyboard Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad T440p Keyboard Replacement: 2 단계, 이미지 2/2
    • Slide the battery latches to the unlocked position.
  3. Lenovo ThinkPad T440p Keyboard Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad T440p Keyboard Replacement: 3 단계, 이미지 2/2
    • Slide the battery pack out of the battery slot.
  4. Lenovo ThinkPad T440p Keyboard Replacement, Keyboard: 4 단계, 이미지 1/3 Lenovo ThinkPad T440p Keyboard Replacement, Keyboard: 4 단계, 이미지 2/3 Lenovo ThinkPad T440p Keyboard Replacement, Keyboard: 4 단계, 이미지 3/3
    • Using the spudger, move the plastic protector by pressing it down and forward in order to uncover the screws.
  5. Lenovo ThinkPad T440p Keyboard Replacement: 5 단계, 이미지 1/2 Lenovo ThinkPad T440p Keyboard Replacement: 5 단계, 이미지 2/2
    • Don't remove the screws; just loosen them.
    • Unscrew the six screws that are attached to the keyboard by using a Phillips #00 screwdriver.
  6. Lenovo ThinkPad T440p Keyboard Replacement: 6 단계, 이미지 1/3 Lenovo ThinkPad T440p Keyboard Replacement: 6 단계, 이미지 2/3 Lenovo ThinkPad T440p Keyboard Replacement: 6 단계, 이미지 3/3
    • Use the spudger to lift the keyboard.
  7. Lenovo ThinkPad T440p Keyboard Replacement: 7 단계, 이미지 1/2 Lenovo ThinkPad T440p Keyboard Replacement: 7 단계, 이미지 2/2
    • Turn the keyboard over.
  8. Lenovo ThinkPad T440p Keyboard Replacement: 8 단계, 이미지 1/3 Lenovo ThinkPad T440p Keyboard Replacement: 8 단계, 이미지 2/3 Lenovo ThinkPad T440p Keyboard Replacement: 8 단계, 이미지 3/3
    • Use the spudger to detach the plastic protection.
  9. Lenovo ThinkPad T440p Keyboard Replacement: 9 단계, 이미지 1/3 Lenovo ThinkPad T440p Keyboard Replacement: 9 단계, 이미지 2/3 Lenovo ThinkPad T440p Keyboard Replacement: 9 단계, 이미지 3/3
    • Use the spudger to disconnect the cables.
  10. Lenovo ThinkPad T440p Keyboard Replacement: 10 단계, 이미지 1/1
    • Remove the keyboard.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Christian Abad
회원 가입일: 03/20/19
1,378 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team S6-G5, Peak Spring 2019 UMass Dartmouth, Team S6-G5, Peak Spring 2019 회원
UMASSD-PEAK-S19S6G5
3 회원들
안내서 9개 작성하였습니다
댓글 한 개
Thanks for the guide. I hate this part lol.
is it true if I slip and knock keys off, they can’t be lit in? I’m told this and it seems true :(
Josh Tree - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 21
30일 전: 58
전체 시간: 7,051
