소개
The RAM is a simple replacement that only requires your fingers to remove it. Make sure to only apply pressure on the edges and not the RAM itself so as not to damage any parts it might be connected to.
필요한 것
Use a Phillips #1 screwdriver to remove the two 9mm screws holding the back cover.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
