주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T440p Wireless Adapter Replacement
필요한 것
  1. Lenovo ThinkPad T440p Wireless Adapter Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop so that the back is facing up.
  2. Lenovo ThinkPad T440p Wireless Adapter Replacement: 2 단계, 이미지 1/2 Lenovo ThinkPad T440p Wireless Adapter Replacement: 2 단계, 이미지 2/2
    • Slide the battery latches to the unlocked position.
  3. Lenovo ThinkPad T440p Wireless Adapter Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad T440p Wireless Adapter Replacement: 3 단계, 이미지 2/2
    • Slide the battery pack out of the battery slot.
  4. Lenovo ThinkPad T440p Wireless Adapter Replacement, Back Cover: 4 단계, 이미지 1/2 Lenovo ThinkPad T440p Wireless Adapter Replacement, Back Cover: 4 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the two 9mm screws holding the back cover.
  5. Lenovo ThinkPad T440p Wireless Adapter Replacement: 5 단계, 이미지 1/1
    • Slide down the back cover.
  6. Lenovo ThinkPad T440p Wireless Adapter Replacement: 6 단계, 이미지 1/1
    • Remove the back cover.
  7. Lenovo ThinkPad T440p Wireless Adapter Replacement, Wireless Adapter: 7 단계, 이미지 1/2 Lenovo ThinkPad T440p Wireless Adapter Replacement, Wireless Adapter: 7 단계, 이미지 2/2
    • Use the spudger to remove the two cables that are connected to the wireless adapter.
  8. Lenovo ThinkPad T440p Wireless Adapter Replacement: 8 단계, 이미지 1/2 Lenovo ThinkPad T440p Wireless Adapter Replacement: 8 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove one 3 mm screw holding down the wireless adapter. Once it is done, the wireless adapter will move to an upward angle.
  9. Lenovo ThinkPad T440p Wireless Adapter Replacement: 9 단계, 이미지 1/2 Lenovo ThinkPad T440p Wireless Adapter Replacement: 9 단계, 이미지 2/2
    • Remove the wireless adapter.
결론
Christian Abad
회원 가입일: 03/20/19
1,378 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team S6-G5, Peak Spring 2019 UMass Dartmouth, Team S6-G5, Peak Spring 2019 회원
UMASSD-PEAK-S19S6G5
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 37
전체 시간: 1,844
