소개
This guide requires some caution when removing the cables connected to the wireless adapter. Use a spudger and avoid using tweezers with metallic points as it could damage the cable. The remainder of the guide is simple and requires unscrewing a screw.
필요한 것
Use a Phillips #1 screwdriver to remove the two 8mm screws holding the back cover.
Use the spudger to remove the two cables that are connected to the wireless adapter.
다른 한 분이 해당 안내서를 완성하였습니다.
