주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T460 Internal Battery Replacement
필요한 것
  1. Lenovo ThinkPad T460 Internal Battery Replacement, External Battery: 1 단계, 이미지 1/3 Lenovo ThinkPad T460 Internal Battery Replacement, External Battery: 1 단계, 이미지 2/3 Lenovo ThinkPad T460 Internal Battery Replacement, External Battery: 1 단계, 이미지 3/3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T460 Internal Battery Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T460 Internal Battery Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T460 Internal Battery Replacement: 2 단계, 이미지 3/3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T460 Internal Battery Replacement, Bottom Cover: 3 단계, 이미지 1/2 Lenovo ThinkPad T460 Internal Battery Replacement, Bottom Cover: 3 단계, 이미지 2/2
    • Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
  4. Lenovo ThinkPad T460 Internal Battery Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad T460 Internal Battery Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad T460 Internal Battery Replacement: 4 단계, 이미지 3/3
    • Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
    • Pry the lower left corner of the bottom cover up by a few millimeters.
    • Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
    • You may hear some snapping noises as the clips are released.
  5. Lenovo ThinkPad T460 Internal Battery Replacement: 5 단계, 이미지 1/2 Lenovo ThinkPad T460 Internal Battery Replacement: 5 단계, 이미지 2/2
    • Slide the spudger along the right and top sides of the bottom cover to release the clips.
    • Potential for device damage: If the clips do not release easily, check to ensure that the captive screws are fully loosened. Forcing the clips to detach can crack the bottom cover.
  6. Lenovo ThinkPad T460 Internal Battery Replacement: 6 단계, 이미지 1/2 Lenovo ThinkPad T460 Internal Battery Replacement: 6 단계, 이미지 2/2
    • Use the spudger to pry the upper left corner up by a few millimeters.
    • Pry up the sections of the bottom cover with printed logos of the ports.
    • Potential for device damage: Prying inside the ports themselves can damage your laptop. Be sure to only pry up on the sections of the cover that extend past the ports.
  7. Lenovo ThinkPad T460 Internal Battery Replacement: 7 단계, 이미지 1/2 Lenovo ThinkPad T460 Internal Battery Replacement: 7 단계, 이미지 2/2
    • Use the spudger to pry up the bottom cover in the lower portion of the external battery compartment by a few millimeters.
  8. Lenovo ThinkPad T460 Internal Battery Replacement: 8 단계, 이미지 1/3 Lenovo ThinkPad T460 Internal Battery Replacement: 8 단계, 이미지 2/3 Lenovo ThinkPad T460 Internal Battery Replacement: 8 단계, 이미지 3/3
    • Use both hands to lift the bottom cover up and away from the laptop.
  9. Lenovo ThinkPad T460 Internal Battery Replacement, Internal Battery: 9 단계, 이미지 1/2 Lenovo ThinkPad T460 Internal Battery Replacement, Internal Battery: 9 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a pair of blunt nose tweezers to pull the black connector out of its socket.
    • This connector may be difficult to remove. You can use a pair of tweezers to gently rock the connector back and forth until it is free from the socket.
  10. Lenovo ThinkPad T460 Internal Battery Replacement: 10 단계, 이미지 1/2 Lenovo ThinkPad T460 Internal Battery Replacement: 10 단계, 이미지 2/2
    • Remove the three 3.7 mm screws from the internal battery using a Phillips #1 screwdriver.
  11. Lenovo ThinkPad T460 Internal Battery Replacement: 11 단계, 이미지 1/2 Lenovo ThinkPad T460 Internal Battery Replacement: 11 단계, 이미지 2/2
    • Use your hands to lift the battery up and away from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kristen Gismondi
회원 가입일: 11/12/14
82,272 평판
안내서 200개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,289개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 44
30일 전: 216
전체 시간: 6,557
