주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T460 Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad T460 Keyboard Replacement, External Battery: 1 단계, 이미지 1/3 Lenovo ThinkPad T460 Keyboard Replacement, External Battery: 1 단계, 이미지 2/3 Lenovo ThinkPad T460 Keyboard Replacement, External Battery: 1 단계, 이미지 3/3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T460 Keyboard Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T460 Keyboard Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T460 Keyboard Replacement: 2 단계, 이미지 3/3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T460 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/2 Lenovo ThinkPad T460 Keyboard Replacement, Keyboard: 3 단계, 이미지 2/2
    • Use the pointed end of a spudger to pry the two rubber stoppers out of the battery compartment.
  4. Lenovo ThinkPad T460 Keyboard Replacement: 4 단계, 이미지 1/2 Lenovo ThinkPad T460 Keyboard Replacement: 4 단계, 이미지 2/2
    • Place the laptop so that the top is facing upwards.
    • Open the lid of the laptop.
  5. Lenovo ThinkPad T460 Keyboard Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad T460 Keyboard Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad T460 Keyboard Replacement: 5 단계, 이미지 3/3
    • Use the pointed end of a spudger to push the keyboard towards the screen using the two notches on the bottom of the keyboard.
  6. Lenovo ThinkPad T460 Keyboard Replacement: 6 단계, 이미지 1/2 Lenovo ThinkPad T460 Keyboard Replacement: 6 단계, 이미지 2/2
    • Loosen the six captive screws in the keyboard frame using a Phillips #0 screwdriver.
    • These screws are hard to see. Make sure you have pushed the keyboard towards the screen as far as it will go to see the screws better.
  7. Lenovo ThinkPad T460 Keyboard Replacement: 7 단계, 이미지 1/2 Lenovo ThinkPad T460 Keyboard Replacement: 7 단계, 이미지 2/2
    • Use your hands to pull the keyboard up and towards you by a few millimeters to remove it from its tray.
    • Potential for device damage: The keyboard is still attached to the rest of the laptop, so be gentle when lifting it.
  8. Lenovo ThinkPad T460 Keyboard Replacement: 8 단계, 이미지 1/2 Lenovo ThinkPad T460 Keyboard Replacement: 8 단계, 이미지 2/2
    • Grab the bottom edge of the keyboard with your hands, and flip the keyboard upside-down, so it rests on the bottom of the laptop.
    • Potential for device damage: The keyboard is still attached to the rest of the laptop, so be gentle when flipping it over.
  9. Lenovo ThinkPad T460 Keyboard Replacement: 9 단계, 이미지 1/2 Lenovo ThinkPad T460 Keyboard Replacement: 9 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a pair of blunt-nosed tweezers to lift the black flap away from the cable connectors.
  10. Lenovo ThinkPad T460 Keyboard Replacement: 10 단계, 이미지 1/2 Lenovo ThinkPad T460 Keyboard Replacement: 10 단계, 이미지 2/2
    • Use the flat end of a spudger to flip up the locking flap securing the ribbon cable.
  11. Lenovo ThinkPad T460 Keyboard Replacement: 11 단계, 이미지 1/2 Lenovo ThinkPad T460 Keyboard Replacement: 11 단계, 이미지 2/2
    • Use a pair of blunt-nosed tweezers to pull the ribbon cable out of its connector.
  12. Lenovo ThinkPad T460 Keyboard Replacement: 12 단계, 이미지 1/2 Lenovo ThinkPad T460 Keyboard Replacement: 12 단계, 이미지 2/2
    • Use the flat end of a spudger to flip up the locking flap securing the bottom ribbon cable.
  13. Lenovo ThinkPad T460 Keyboard Replacement: 13 단계, 이미지 1/2 Lenovo ThinkPad T460 Keyboard Replacement: 13 단계, 이미지 2/2
  14. Lenovo ThinkPad T460 Keyboard Replacement: 14 단계, 이미지 1/2 Lenovo ThinkPad T460 Keyboard Replacement: 14 단계, 이미지 2/2
    • Pull the ribbon cables through the slot in the black flap.
    • Remove the black flap from the keyboard.
  15. Lenovo ThinkPad T460 Keyboard Replacement: 15 단계, 이미지 1/2 Lenovo ThinkPad T460 Keyboard Replacement: 15 단계, 이미지 2/2
    • Use your hands to lift the keyboard up and away from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kristen Gismondi
회원 가입일: 11/12/14
82,335 평판
안내서 200개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,303개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 29
30일 전: 174
전체 시간: 5,437
