소개
If the Lenovo ThinkPad T460s(all modes) is slowing down after opening 20 ish Chrome tabs or lots of applications, use this guide to replace a larger RAM or add more RAM to the laptop will solve the problem.
RAM modules are used for providing fast-access storage for the operating system to function.
Before you start with this guide, make sure you have powered off your laptop and you have the replacement ram ready. The ram that comes with this laptop is ddr4 2400 MHz. Ideally, you need to find a RAM module with the same specs. A faulty RAM will result in an unbootable laptop.
Make sure you have the right-sized the screwdriver, so you will not strip your screws.
필요한 것
Remove the five 5.5mm Phillips #1 screws securing the back cover.
Lift and remove the back cover.
다른 3명이 해당 안내서를 완성하였습니다.
