주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T460s RAM Replacement
필요한 것
  1. Lenovo ThinkPad T460s RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s RAM Replacement: 2 단계, 이미지 1/1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s RAM Replacement: 3 단계, 이미지 1/1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s RAM Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad T460s RAM Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad T460s RAM Replacement: 4 단계, 이미지 3/3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
  5. Lenovo ThinkPad T460s RAM Replacement, RAM: 5 단계, 이미지 1/3 Lenovo ThinkPad T460s RAM Replacement, RAM: 5 단계, 이미지 2/3 Lenovo ThinkPad T460s RAM Replacement, RAM: 5 단계, 이미지 3/3
    • To remove the existing RAM module, pull tabs marked in the red outwards.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jingyu Su
회원 가입일: 10/01/19
303 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 14
30일 전: 96
전체 시간: 4,657
